MAGOO1916 Posted October 8, 2022 Share Posted October 8, 2022 Anyone know the location of this module part no is 4h4 907 357 e Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted October 9, 2022 Share Posted October 9, 2022 On 10/8/2022 at 5:11 PM, MAGOO1916 said: Anyone know the location of this module part no is 4h4 907 357 e Hi do you mean the light range control unit, if so its under the scuttle cover on the outside of the car on the side where the fresh air sensor [peculiar brown/black thing] is mounted. Steve. Quote Link to comment Share on other sites More sharing options...
MAGOO1916 Posted October 9, 2022 Author Share Posted October 9, 2022 4 minutes ago, Stevey Y said: Hi do you mean the light range control unit, if so its under the scuttle cover on the outside of the car on the side where the fresh air sensor [peculiar brown/black thing] is mounted. Steve. Thanks ill have a look is this under the bonnet mate Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted October 9, 2022 Share Posted October 9, 2022 1 minute ago, MAGOO1916 said: Thanks ill have a look is this under the bonnet mate Its a small back box and the connector plug becomes corroded, mine was only like it one side so the left hand beam was searching for coins in the gutter, cleaned it and the lights levelled as they should. Quote Link to comment Share on other sites More sharing options...
MAGOO1916 Posted October 9, 2022 Author Share Posted October 9, 2022 51 minutes ago, Stevey Y said: Its a small back box and the connector plug becomes corroded, mine was only like it one side so the left hand beam was searching for coins in the gutter, cleaned it and the lights levelled as they should. Had a look this the one under the washer fluid bottle to the left Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted October 10, 2022 Share Posted October 10, 2022 On 10/9/2022 at 7:00 PM, MAGOO1916 said: Had a look this the one under the washer fluid bottle to the left Hi probably, its a bit of a sod to get to but doable. Steve. Quote Link to comment Share on other sites More sharing options...
