Oil in cooling system
Hi guys, I’ve recently bought an A4 b7 2.0 tdi Quattro special edition 2007, it went into limp mode  but once left for a while it starts and drives  fine  but I noticed oil in the expansion tank and it’s losing about half an inch of water a week , the car drives perfect  I’ve had the oil cooler replaced the Egr cooler replaced  the cooling system cleaned out but it’s still happening , no coloured smoke from the exhaust,  has anyone had a similar issues and how to rectify it  cheers
Hi the only way to find out is have the car scanned for codes, absent any codes have the coolant system pressure tested, unfortunately it sound like a head gasket has a small leak between a water and oil gallery.
I agree with Steve. It does sound like a head gasket problem.
Tony
The garage says no but there is some milk on the rocker cover and the oil level seems too high
Unfortunately if you have had the oil cooler changed already then the only suspect left is the head gasket as mentioned above.
Thanks guys , just off chance could the oil pump have anything to do with this  , I believe that there is an issue with this pump and that there is an upgrade 🤷‍♂️
