kris69420 Posted October 11, 2023 Share Posted October 11, 2023 I bought myself 2003 Audi A3 8P a few months ago, and since then, my ESP light on the cluster has been staying a bit illuminated. Anyone know what the issue might be? Can it be a blown bulb? Quote Link to comment Share on other sites More sharing options...
Magnet Posted October 12, 2023 Share Posted October 12, 2023 Hello Kristiyan, Welcome to the forum. One thing it wouldn’t be is a blown bulb - it wouldn’t illuminate at all. This could be a weak signal from one of the ABS wheel sensors or senders, but regrettably you will need to have the car diagnostically checked to give you a good indication where the fault lies. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Solution kris69420 Posted October 12, 2023 Author Solution Share Posted October 12, 2023 (edited) 7 hours ago, Magnet said: Hello Kristiyan, Welcome to the forum. One thing it wouldn’t be is a blown bulb - it wouldn’t illuminate at all. This could be a weak signal from one of the ABS wheel sensors or senders, but regrettably you will need to have the car diagnostically checked to give you a good indication where the fault lies. Kind regards, Gareth. I got it checked via VCDS and got a steering angle sensor fault. And that I needed to do a system function test to remove the fault. Edited October 12, 2023 by kris69420 1 Quote Link to comment Share on other sites More sharing options...
