Robere Posted November 2, 2023 Share Posted November 2, 2023 (edited) Hi. Everytime I open the filler cap there is quite often a little puddle of water. And lately seems like diesel. Why is this ?? Edited November 2, 2023 by Robere Quote Link to comment Share on other sites More sharing options...
Magnet Posted November 2, 2023 Share Posted November 2, 2023 Thanks Robert and welcome. When you say ‘open the filler cap’ do you really mean fuel cap, or fuel flap? Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Robere Posted November 2, 2023 Author Share Posted November 2, 2023 Fuel flap. As you open it where you put fuel in where nozzle goes just below inside door water or even diesel lies Quote Link to comment Share on other sites More sharing options...
Magnet Posted November 3, 2023 Share Posted November 3, 2023 That sounds much clearer Robert, and now makes sense. If you open the flap as normal and without removing the cap, thoroughly clean around the cap area and all inside the area that the flap conceals. You should then see a small rubber grommet or similar, in the bottom of the cleaned area - usually directly below the filler cap -i.e. at the lowest point of the compartment. You should then see a small (3mm or so) hole in the centre of the grommet which ( when clear - important) allows rainwater to run away. Get a length of suitable flexible wire and push that through to clear the blockage - which is likely to be further down. Diesel sometimes? Dribbles of diesel out of the fuel hose when returning the hose to the pump. Let us know how you get on. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Robere Posted November 10, 2023 Author Share Posted November 10, 2023 Perfect all sorted thanks for sound advise 1 Quote Link to comment Share on other sites More sharing options...
Steve Q Posted November 10, 2023 Share Posted November 10, 2023 Is the little hole below the filler neck blocked? It's a hole that's supposed to be a drain. Quote Link to comment Share on other sites More sharing options...
