Q7 2014 3.0TDI Aircon Issue NoCodes in VCDS
Hi Guys,
Not sure if anybody had that issue.
I can press AC button and it stays on.
Change in airflow (a bit ) but no cold air.
No error codes in VCDS/Autel.
Any advise or anything to check
I think that the compress is reacting. It changed the torque setting slight. The air flow changes between AC being turned on and off.
Compress is clutch less but seems to be working.
IMG_0127.HEIC IMG_0128.HEIC IMG_0120.HEIC
Getting it check on Tuesday for leakage.
No leaks were found it was a bit low on gas hence the issue but not enough to cause any errors codes.
Thanks for the advise
Hi Team,
It's sorted yes. It was as simple as that.
I don't have option to set my name or I am missing something?
The firstname field is not there.
3 minutes ago, Trevor said:
That issue should now be sorted and have entered your name in your profile for you
Thanks all good
