1st gear clutch judder audi a4 b8 2.0tdi
Hi all,looking for some advice, my wife's a4 had started juddering when pulling away in 1st gear then stopped doing it for about a week then came back again and weirdly today it didn't do it,do you think this could be air in the sytem/contaminated fluid or something more serious, apart from this clutch feels perfect,thanks again.
Solved by Gordy123
Hello Gordon,
It could be either of your options, but I doubt it.
Possibly contaminated clutch plate - engine oil or clutch fluid, or the start of the failure of the clutch slave cylinder etc.  but worth getting gearbox and engine mountings checked.
You could try:- in a safe place, and with no forward obstructions , put the car in second gear and bring the clutch pedal up slowly until you just reach the bite point. Hold revs at say a steady 1500rpm and depress and gently release the clutch pedal just in and out of the bite point. Keep doing that for a couple to three minutes and see if that results in any (temporary?) imprevement.
Kind rergards,
  • Solution
Cheers mate ,really hope it's not the clutch/flywheel or something else on the way out 👍
  • 3 months later...
Hi, did you find the solution to this problem?
Nope car is still running fine ,sometimes does it then it just stops doing it ,so she has learned to live with it lol
