Constant drain on my battery over night
Sick of constantly jumping starting my motor due to parcidic battery drain
Changed my CCM module
And went through all my fuses
With a multimeter
But no luck
Any ideas
How large is the overnight drain? A few dozen milliamps is normal.
Have you any fitted any extra electrical equipment such as dashcam or satnav that may not be controlled by the ignition switch? If so, disconnect them and measure the drain again.
If I'm using my multimeter properly it was so sitting at 1.1 milliamps
Edited by Danny fisher
Danny.
If that is a true reading, although it does seem very low, I suggest the battery is clapped out because of an internal fault. It would be wise to get it professionally tested before splashing out cash on a new battery and ensure you get it coded to the car.
