Flat battery
Hi folks. My 2013 A6 has been sitting for around six months and has a completely flat battery. Is there anyway to open the boot manually?
Solved by cliffcoggin
There’s usually a key hole ( very often partially concealed) that allows you to open the boot manually.
Can you get into the car via. a key,,and if so I take it you can then open the bonnet?
If the bonnet can be opened, you can attach a charger to the charging point !
If the bonnet can be opened, you can attach a charger to thecharging point !
Brilliant folks, thanks
Charged the battery.......car still completely dead bar a few dash lights at the bottom.
3 minutes ago, cliffcoggin said:
New battery needed. Don't forget to get it coded to the car.
Yeah  unfortunately so.
Walking past the car this morning and these lights are randomly lit. I'm guessing this is just because the battery has died a sorry death?
