Help.needed with reverse camera wiring
Hi guys , I'm.after some advise ,I've fitted a reverse camera on my daughters a3 ,it's a aftermarket one . Can anyone tell.me where to wire the 12v feed to the reverse light thanks
Only just seen this. Probably easiest route is the reversing light.
Tried  its can bus so voltage is wrong
You can buy 12v to 5v converters on the net for £5. Used them in the past for phone charging.
