One-touch window failure
Hi there - i checked through all the pages related to A5 but didn't see anything on this topic on issues with the one-touch open/close function.
I have an Audi A5 Cab B9/F5 40 TFSI S line (pre-facelift) and on the cabriolets, you have 4 switches, one for each window, plus a 5th master which does all the windows at the same time. Each switch has the one-touch operation. The rear window switches and the 5th master switch work up/down with one touch no problems.
Problem I have: The front window switches, driver and passenger, are not working as expected. Both have the same problem with the one-touch function when you want to open the windows. I have to manually hold the switch until they are fully open. It seems to only be opening them where the issue is as they both close fine using one-touch. NOTE: they also open fine on one-touch from the master switch.
Possible solutions I have tried:
I have tried the re-programming approach to lower and hold for 10-15 seconds and then raise and hold for 10-15 seconds. But not sure if I am doing it right or if there is an authoritative source on the exact process? Maybe I need the ignition on? Maybe I need to lower first then raise, or raise first then lower?
Possible solutions I am aware of:
Would disconnecting and reconnecting the battery force a reset? Could I impact other items by doing this though, will this lose any other settings or config I should check first?
Replacing the switches might fix it but whether or not the behaviour above points to this or is it more a re-programming issue than a hardware?
Cleaning the switches might also be something to try? Removing the switches from the arm rest, giving them a magic blow/spray with electrical contact cleaner.
Help I need:
  • does anyone know the specific re-programming process I need to follow? Not sure if it's documented anywhere?
  • if I disconnect and reconnect the battery, is there any risk to any of the other systems? Not bothered about losing radio stations, MMI settings, NAV favourites as I use Apple CarPlay. Trying to think of any other settings I might worry about if they were reset...
  • any other options before I go down the cleaning or replacement of the switches
Thank you in advance!!
That is the right technique, but the ignition needs to be on.
Hi there. No luck I’m afraid. Just literally tried it again sat on the driveway.
Ignition/engine on, all windows closed. Single click roll the driver window down. Release and then press done two clicks and hold for 10-15 seconds.
Single click roll window up to top, release and pull up two clicks and hold for 15 seconds.
Then nothing. One click still not working to open drivers window.
One click works to close the window but not open
Sorry that’s not working either…. Very strange. Do I try and get someone to check the computer? Or should I try and check the control units on the drivers side door??
