DRL issue
Hi folks - i'm a new member ....promise to not be one of those post-n-run noobs!
I recently changed 12v battery on my 2009 facelift model - and the white DRL's no longer light up, although they do still light up orange when indicating.
I kept a trickle charge during battery swap too, so nothing was reset.
DRL's are enabled in MMI (exterior illumination) also.
Any simple things i can rule out ? (i haven't got vagcom)
nevermind....i'm being a numpty ! these never lit white in the first place
You're right, strictly speaking, it should be coded. I've got an old OBDElevan, can't recall if it was possible using that, so will give that a try. If not then a local mech has vcds, so will give them a shout.
