Reavley Posted April 21 Posted April 21 Hello, I have a 2017 B9 2.0 petrol. I've recently had dash warnings the start/stop and drive system fault. The first few times the faults cleared with turning it off and on again. But now the engine dash light is permanently on yellow. I will take it to a local garage for a diagnostic but wanted to have a bit dig myself too. I saw it could be an issue with the battery so thought I'd test the voltage with a cheap multimeter I had. The readings I got were 12.5v with engine off, and 12.9v with engine on. Are those readings ok or could there be an issue with the battery? Cheers Martin
cliffcoggin Posted April 21 Posted April 21 Those readings have little relevence, so you could indeed have a faulty battery. The symptoms you report are consistent with a dying battery which can not provide the stable power supply needed by the car's electronics. If it is the original eight year old battery I suggest you replace it as soon as practical, and ensure you get it coded to the car. See this for an explanation why: https://www.youtube.com/watch?v=IJAScg6JrYI 1
daveyboy1967 Posted April 21 Posted April 21 5 hours ago, Reavley said: he readings I got were 12.5v with engine off, and 12.9v with engine on. I would expect to see somewhere around 14.4V at the battery with the engine running. It sounds like this could be an alternator problem rather than the battery. 1
Reavley Posted April 21 Author Posted April 21 Thank you both. Would that be 14.4v straight after turning the engine on or does it take some time to build to that? The 12.9v I got with engine on was straight after ignition. Thank you
daveyboy1967 Posted April 21 Posted April 21 By the time you've started, lifted the bonnet and checked the voltage you should see that voltage, pretty much as soon as the alternator is spinning.
Magnet Posted April 21 Posted April 21 Hell Martin, Are you talking the 12.9v with the engine running? ‘Engine on’ is rather ambiguous. If it were mine, I would first take the car to an Halfords store and get the battery efficiency checked there. Also ask them to check the alternator output at the same time. I wouldn’t take it to a local garage and get ‘diagnostics’ carried out. At best they are likely to inform you the battery is duff and probably fit a ‘best deal for them at their motorfactors’. If Halfords declares the battery and/or alternator to be defective, please come back to us before committing to purchase any part or repair. Kind regards, Gareth.
daveyboy1967 Posted April 21 Posted April 21 Just for reference Martin, mine just now with engine running. 1
daveyboy1967 Posted April 21 Posted April 21 It could be something as simple as a loose belt, you're getting some output from your alternator as the voltage is higher with the engine running than when turned off, but it's nowhere near enough. You should definitely get it checked by a decent mechanic before you end up ruining what could be a perfectly decent battery.
Magnet Posted April 21 Posted April 21 Martin, could you please clarify your ‘engine on’. Thanks, Gareth.
daveyboy1967 Posted April 21 Posted April 21 2 hours ago, Reavley said: The 12.9v I got with engine on was straight after ignition. I'm pretty sure he means running Gareth.
Magnet Posted April 21 Posted April 21 Thanks Dave, but I don’t do pretty sures, we need to deal only in confirmed fact on here, otherwise they are assumptions. Kind regards, Gareth.
daveyboy1967 Posted April 21 Posted April 21 He would see a voltage drop with the ignition energised but with the engine not running when compared to an at rest reading.
Reavley Posted April 21 Author Posted April 21 Apologies for the ambiguity Gareth... I did indeed mean engine running when I said engine on. I'm no fan of Halfords but I have messaged a local independent mechanic, who I've used in the past and had positive experiences with, to book the car in for him to look at. I note Cliff's point about having the battery coded to the car and will ensure if I do end up needing a new battery I will make sure it is somewhere that can code it to the car. Really appreciate your notes on a potential belt or alternator Davey. Handy to have a few potential causes in mind when the mechanic gives their opinion.
Magnet Posted April 22 Posted April 22 Does indeed now sound like an alternator issue. Beware of replacement aftermarket alternators - as opposed to getting yours repaired. Kind regards, Gareth. 1
Reavley Posted May 4 Author Posted May 4 I took the car to a local mechanic. He was not concerned with what I thought might be a low voltage at the battery terminals whilst the engine was running as he said the car has smart charging which involves varying voltages. He ran a diagnostic and could see some warnings relating to something along the lines of an electronic turbo control unit (can't remember the exact name. I have the diagnostic report printout but not with me right now). He reckons it would be £300-£400 fitted incl VAT. He cleared the warning light from the dash and suggested I see how it goes before making a decision on what to do. Unfortunately I have been getting the drive system fault dash warnings since. But interestingly it has been manifesting a little differently. Previously the warning would tend to come on part way through a journey. But recently it has tended to be when turning on the engine ignition whilst the engine was already warm from a recent drive. I haven't yet had the warning whilst starting the ignition from cold.
Magnet Posted May 4 Posted May 4 As suggested - just take it to Halfords and get the alternator output checked.
spartacus 68 Posted May 5 Posted May 5 Personally I’d swop out the battery. On 2017 car that’s now 8 years old and these cars are very picky about voltage drop or you get into all sorts of issues. Go AGM and get it coded to car, clear fault codes and go from there.
Magnet Posted May 5 Posted May 5 It’s not a question of trust Martin, it a question of actual values and their significance. Appreciating opinions differ, but I wouldn’t be in any hurry to replace an expensive battery before confirming that your alternator output is indeed what it should be. Getting the battery tested would be a progressive move however - subject to it being fully charged at the point of testing.
Magnet Posted yesterday at 06:38 PM Posted yesterday at 06:38 PM Hello Martin, We can see you have returned to the forum since yesterday’s post requesting an update. Any good reason why you are not responding?
daveyboy1967 Posted 22 hours ago Posted 22 hours ago I'm getting the feeling we won't hear from him again until he has another problem and needs some more advice Gareth. Getting all too common unfortunately.
