Saj786 Posted Sunday at 07:41 PM Posted Sunday at 07:41 PM Guys my S3 has been creaking from the front left side every time I turn left, it’s more prone when it’s slower, I’ve had ball joint and track rod end changed, no joy. It’s so annoying!! It’s sounds like a dry rubbery sound but can’t find what it is… It’s actually worse when the weather is warmer on a hot day. Any suggestions as I don’t want to keep spending loads and it still be there. Mechanic said process of elimination, could be top mount or steering rack. Tbf before it used to come and go, but as weather is warmer now i can hear it a lot more. Anybody had this issue, any suggestions or help would be appreciated
spartacus 68 Posted Sunday at 10:55 PM Posted Sunday at 10:55 PM Worn drop links or ARB bushes. Both inexpensive.
Saj786 Posted Sunday at 10:58 PM Author Posted Sunday at 10:58 PM Would droplink sound rubbery ? Creaking ??
spartacus 68 Posted Sunday at 11:00 PM Posted Sunday at 11:00 PM (edited) Potentially if the balljoints are goosed. My money is on ARB bushes. Wouldn’t expect top mounts to have gone on 2017 car unless high mileage. Edited Sunday at 11:01 PM by spartacus 68
Saj786 Posted Sunday at 11:01 PM Author Posted Sunday at 11:01 PM I had the ball joint replaced mate, but if you think ARB bushes, is it an easy job to replace?
spartacus 68 Posted yesterday at 06:51 AM Posted yesterday at 06:51 AM Jack up the car at the front, on both sides, drop the engine under tray, and you can access bolts to ARB. Wire brush first and spray with penetrating release, buzz the bolts off if you have a power driver. You will also need to remove the drop links too. If the drop links have play at balljoints, replace with Meyle HD. On fitting new bushes, use red rubber grease. Don’t use any other grease.
Saj786 Posted yesterday at 07:49 AM Author Posted yesterday at 07:49 AM Thanks, I’ll have to probably get them done by mechanic .
Magnet Posted yesterday at 08:22 AM Posted yesterday at 08:22 AM Thanks Saj, I would suggest it’s well worth getting your mechanic to check them first - rather than just embarking on changing them when they are serviceable. Possible suspect - top suspension mount?? Kind regards, Gareth.
Saj786 Posted yesterday at 08:46 AM Author Posted yesterday at 08:46 AM Top suspension mount is what mechanic thinks too, only thing if get that replaced and it’s not that 🤦🏼♂️, it’s strange as only happens when slow left turn, but annoying …, it’s sounds similar like a creaking old door opening
