Saj786 Posted May 4 Posted May 4 Guys my S3 has been creaking from the front left side every time I turn left, it’s more prone when it’s slower, I’ve had ball joint and track rod end changed, no joy. It’s so annoying!! It’s sounds like a dry rubbery sound but can’t find what it is… It’s actually worse when the weather is warmer on a hot day. Any suggestions as I don’t want to keep spending loads and it still be there. Mechanic said process of elimination, could be top mount or steering rack. Tbf before it used to come and go, but as weather is warmer now i can hear it a lot more. Anybody had this issue, any suggestions or help would be appreciated
spartacus 68 Posted May 4 Posted May 4 (edited) Potentially if the balljoints are goosed. My money is on ARB bushes. Wouldn’t expect top mounts to have gone on 2017 car unless high mileage. Edited May 4 by spartacus 68
Saj786 Posted May 4 Author Posted May 4 I had the ball joint replaced mate, but if you think ARB bushes, is it an easy job to replace?
spartacus 68 Posted May 5 Posted May 5 Jack up the car at the front, on both sides, drop the engine under tray, and you can access bolts to ARB. Wire brush first and spray with penetrating release, buzz the bolts off if you have a power driver. You will also need to remove the drop links too. If the drop links have play at balljoints, replace with Meyle HD. On fitting new bushes, use red rubber grease. Don’t use any other grease.
Magnet Posted May 5 Posted May 5 Thanks Saj, I would suggest it’s well worth getting your mechanic to check them first - rather than just embarking on changing them when they are serviceable. Possible suspect - top suspension mount?? Kind regards, Gareth.
Saj786 Posted May 5 Author Posted May 5 Top suspension mount is what mechanic thinks too, only thing if get that replaced and it’s not that 🤦🏼♂️, it’s strange as only happens when slow left turn, but annoying …, it’s sounds similar like a creaking old door opening
enc Posted May 6 Posted May 6 (edited) had same issue with mine. I suspected top mounts. had top mounts, dampers and drop links replaced. been fine for 12 months but now getting the odd creak again. i used Febi Bilstein top mounts and drop links and OEM spec Sachs dampers. Edited May 6 by enc 1
Saj786 Posted May 6 Author Posted May 6 R u sure it will be top mount as some people say anti roll bar bushes lol
enc Posted May 7 Posted May 7 (edited) 12 hours ago, Saj786 said: R u sure it will be top mount as some people say anti roll bar bushes lol No I’m not sure. But it was ok for 12 months after changing. . Dampers were originals so needed changing anyway Edited May 7 by enc
Saj786 Posted May 7 Author Posted May 7 Tbf one the mechanics reckons it is the top mount as, but it takes a while to do 🤔
enc Posted May 7 Posted May 7 (edited) you can usually tell by looking at arb bushes if they have deteriorated. Fairly simple job to swap out compared to top mounts which are more involved. top mounts, you cant tell for certain until you remove them from the car (unless they’re really bad) perhaps, your mechanic can advise further Edited May 7 by enc
Saj786 Posted Wednesday at 02:33 PM Author Posted Wednesday at 02:33 PM So just an update, I’ve had top mount replaced, track rod end, ball joint and drop link all replaced at a cost !! but the creaking noise is STILL there !!!! mostly on a slow left turn it’s like a creak, springy sound. I’m sick of throwing money at it. Any advice would be greatly appreciated!!!
spartacus 68 Posted Wednesday at 10:07 PM Posted Wednesday at 10:07 PM Not sure what else to suggest. A mechanic will get a pry bar on the lower arm bushes. Any flex, then swap it out. On the bright side you’re rebuilding the front suspension piece by piece. 😉 Double check the coil spring hasn’t lost an end and it’s sitting properly. I’m sure if you had top mounts done that would have been spotted.
Saj786 Posted Wednesday at 10:09 PM Author Posted Wednesday at 10:09 PM Spring should be ok as new top mount replaced, someone suggested it could be swaybar bushes…it’s so annoying and now my mechanic suggested going to an Audi specialist fgs…..
Saj786 Posted 12 hours ago Author Posted 12 hours ago Guys !! regarding the creaking noise on the left side front. It only happens when I turn left slowly when parking up etc… I’ve had top mount, ball joint, track rod end and drop link replaced but the issue is still there. I’m sick of spending and not getting to the issue. I’ve booked it in for a diagnostic with an Audi specialist next Friday. The mechanic who’s done the previous jobs advised to do that. I’ve added a video with the sound of the issue. If anyone has had the same issue any advice would be appreciated. Someone has said change tie rod arm. IMG_7325.mov
enc Posted 10 hours ago Posted 10 hours ago tahts pretty much the same sound as mine. as previously posted above, I had a few parts replaced and it was pretty much sorted but very ocasionally, it has started to do it again. im watching this thread with interest. fingers crossed your Audi specialist solves it for you. hope you post back here with their findings.
Saj786 Posted 10 hours ago Author Posted 10 hours ago What was the fault on urs then, what was replaced??
enc Posted 8 hours ago Posted 8 hours ago 1 hour ago, Saj786 said: What was the fault on urs then, what was replaced?? as i posted ...above
Saj786 Posted 2 hours ago Author Posted 2 hours ago What was the outcome ?, what did they replace & did they say what was causing the noise?
