Aidenj Posted 17 hours ago Posted 17 hours ago Good morning聽馃檪 Hopefully someone could offer some help regarding my issue regarding the brake wear indicator warning light . It started last year intermittent then on at all times . I got the front pads and sensor changed light went off at least for a while to then return a few months later. At this point I went back and bit the bullet to get the rear pads changed to no avail my mechanic suspects a break in the cable . He is an old school mechanic so freely admitted wiring isn't his strong point . My father in law is pretty decent and we had a go checking what we could . Has anyone had this issue before and if so what did you find .聽 Thanks in advance聽 Jamie聽
Kev-P Posted 14 hours ago Posted 14 hours ago Did you have the sensors changed on the rear when replacing the pads? I would imagine a diagnostic will be able to point you in the direction of which sensor is throwing the code. 1
Aidenj Posted 14 hours ago Author Posted 14 hours ago Thanks for the reply .Yeah we changed them on both and even tried linking out . We put the scanner on with no results unfortunately聽馃ゴ
