bt80k Posted 4 hours ago Posted 4 hours ago Hi guys I own a 1991 B3 16v quattro that's not moved for about 12 years and I've decided it's time to get the old girl back on the road, my first point of call is the fuel system so new pump and filter but would like to clear the system of all the old stuff. What would be the best way to go about this before I start on the other fluids. Thanks
cliffcoggin Posted 4 hours ago Posted 4 hours ago If the fuel tank is steel there's the potential for a lot of rust to have formed in it during 12 years of inactivity. If it is possible, which I do not know, I would want to remove the tank and vigourously slosh a gallon of fuel around before pouring it from the filler neck, then repeat until no more rust is seen. The fuel guage will have to be removed so that is the ideal opportunity to test it. If the tank is plastic there will naturally be no rust, but there may well be condensed water which needs to be removed somehow. I doubt there is a drain plug so maybe a syphon pump down the filler neck would do the job.
bt80k Posted 2 hours ago Author Posted 2 hours ago Cheers for that seems straight forward enough to get the tank out, it's metal. Any suggestions on cleaning fuel lines & pipes.
cliffcoggin Posted 1 hour ago Posted 1 hour ago A blast of compressed air should shift any crud/water/fuel in open-ended lines. If you don't have compressed air I don't know what to suggest. 1
