George42 Posted 11 hours ago Posted 11 hours ago Hello, my 2013 Audi A4 2.0TDI 163PS has this weird issue. It takes around 3-5km for the engine to reach 90celsius, if i drive outside city few km then i go back into driving 1-2-3gear (city conditions) engine temperature drops slightly (to 85-88), if i Idle in neutral 5mins after engine ran constantly at 90celsius, the engine temperature drops to 80celsius, also if i drive on highway (150kmph) then is a portion of highway with 80speed limit it does the same...is this normal for this engine or i have to look into it? weather conditions: 12-15 celsius i recently changed the thermostat and the coolant (thought that might solve the issue). thank you.
cliffcoggin Posted 9 hours ago Posted 9 hours ago George. I suspect the electric cooling fans are not switching off when the engine temperature drops.
George42 Posted 9 hours ago Author Posted 9 hours ago Hi, if you talk about the ones mounted on the radiator then yes, they are not swtiching off...also, they always spin when AC is ON. are you saying this is not normal behavior?
Solution cliffcoggin Posted 5 hours ago Solution Posted 5 hours ago The fans should only run when the temperature is high. I believe there is a module that controls the fans which you may need to renew, but I do not know the details, so a first step would be to get it tested.
George42 Posted 2 hours ago Author Posted 2 hours ago I did another test, drove a little bit in city to raise the engine temp to 90, parked, checked the radiator fans they were blowing hard, then shut off the AC and the fans stopped as well even though the engine was at 90 and it didn't drop... it seems like only after i drive on highway is doing it.
