Airbag light stuck on
Hi guys, I have a 2010 Audi A3 S-line........ I have a Airbag light which wont go away, any ideas please??
I have just changed the Heater blower motor so I guess one of the connections to the glove box which I had to remove was for the airbag, but all put back together now and its still there!!
I used to keep getting the same problem on my '04 A3. It used to happen every time I gave my mate a lift (putting it politely he's generously built). Turns out when he put the seat all the way back it was undoing the connector under the seat. Could be worth a look if you put the seat back to work on the blower.
Yes it's the multi plug on the glove box, I had this just the other day, I was messing about with my head unit, while I had the glove box removed the light on the dash and in the binnacle were illuminated, the glove box had the passenger activation key switch inside.
Switch off when connecting it back up
Edited by Rybrook
What switch is this, and where about is it please??
When you remove the glove box, the is a cable connected near the footwell light, has 5 wires I think, this connects the footwell, glovebox and this
Thanks mate, will give it a try and let you know.
