Holster Posted Tuesday at 07:49 PM Posted Tuesday at 07:49 PM Good evening everyone, just wondering if anyone had any ideas regarding the hub and driveshaft on my Audi A1 I needed to replace both these parts after going over a large rock resulting in me smashing my hub and splitting my driveshaft, it’s on the drivers side, I bought a corner suspension for it genuine part second hand, it was from a A1 25 Tfsi on a 2023 plate, mine is A1 30 Tfsi 6 speed manual on a 2022 plate. My mechanic came to fit it, however the hub on the replacement part was a different size to mine, I didn’t expect that so just wondering is this the case or was I sent the wrong part, I didn’t expect that return the items and got a full refund but now I’m confused which one I should be looking for. Any help would be massively appreciated Thanks in advance
cliffcoggin Posted Tuesday at 07:56 PM Posted Tuesday at 07:56 PM It's hardly surprising a different model has different suspension. The spring will likely also differ.
Holster Posted Tuesday at 08:09 PM Author Posted Tuesday at 08:09 PM Driveshaft fit no problem I thought that would have been different not the hub The hub was smaller than mine, I guess the hub has to be from identical model in order to fit.
Holster Posted Tuesday at 08:17 PM Author Posted Tuesday at 08:17 PM 20 minutes ago, cliffcoggin said: It's hardly surprising a different model has different suspension. The spring will likely also differ. Thanks for responding.
alpha omega Posted Tuesday at 08:17 PM Posted Tuesday at 08:17 PM ask your mechanic see if he/she can look it up
Holster Posted Tuesday at 10:52 PM Author Posted Tuesday at 10:52 PM 2 hours ago, alpha omega said: ask your mechanic see if he/she can look it up Yes you would think that but no I am doing the hunting for the parts. Mine have been removed now so I am comparing parts via images and numbers but none seem to be exact.
Magnet Posted yesterday at 08:12 AM Posted yesterday at 08:12 AM Hello Holly, I can understand you being the parts chaser, otherwise you are paying the mechanic for his time to do so. Having said that, I don’t know exactly how you are going about this, where you have looked to date, whether you are set on secondhand parts, and all important - do you know the part number of the hub you are searching for. Perhaps you could colour in this detail for us Holly. Regards, Gareth.
Holster Posted 39 minutes ago Author Posted 39 minutes ago On 6/4/2025 at 9:12 AM, Magnet said: Hello Holly, I can understand you being the parts chaser, otherwise you are paying the mechanic for his time to do so. Having said that, I don’t know exactly how you are going about this, where you have looked to date, whether you are set on secondhand parts, and all important - do you know the part number of the hub you are searching for. Perhaps you could colour in this detail for us Holly. Regards, Gareth. Thanks Gareth i am going to buy the full section this is how they are usually sold on eBay it also seems to be the cheapest option, the part number i am using for a comparison is from the driveshaft difficult to use part number from hub, no barcode or sticker part number. So I am buying the same part number driveshaft with the hub attached, I have now sourced and purchased one I’m hoping this will be the one. Fingers crossed. Thanks again for your response I appreciate it. On 6/3/2025 at 9:17 PM, alpha omega said: ask your mechanic see if he/she can look it up Yes you would think that but no I am doing the hunting for the parts. Mine have been removed now so I am comparing parts via images and numbers but none seem to be exact.
