No idea about those roof lining buttons, but I’ll bet it will look horrendous by the time you’re finished.
The only way to fix properly is to remove, strip off the old headlining, and use new OE VAG roof lining with a suitable contact adhesive. Tools wise, long handled torx screwdrivers, and this special tool for interior grab handles. https://vw.snapon.com/SpecialToolsDetail.aspx?itemId=38730184
There’s curtain airbags in there, so disconnect battery and leave for 30 mins. If this is a B6 Avant, headlining can come out via the tailgate.
Usual electric connections as sun-visors, central convenience lighting, etc. If there’s a sunroof, then the panel detaches around it with metal clips.
Like a '70s hot rod mate!
