John1567890 Posted Thursday at 07:58 PM Posted Thursday at 07:58 PM Hello just after buying 2003 C5 a6 avant I bought the car assuming ccm was the issue for all interior issues. Took it out and I was right but the connectors are destroyed with corrosion. I have a 2001 saloon a6 but the ccm does not match it is only one digit off on the part number the avant has an N and the sallon a K would I be able to use this ccm. I must now try to cut connectors off and solder in new connectors if somebody knows if these ccms are interchangeable that would be very helpful thanks
Steve Q Posted Thursday at 08:07 PM Posted Thursday at 08:07 PM They're not interchangeable. You need to swap the failed part out for one that has the exact same part number 1
John1567890 Posted Thursday at 08:11 PM Author Posted Thursday at 08:11 PM Okay thank you yes I was thinking that this would be the case alright would I be able to take connectors from the saloon and solder the wiring into the estate connectors the same and wires are the same colours going to each pin also after I replace the ccm will have to reprogram the ccm ?
Steve Q Posted 18 hours ago Posted 18 hours ago 13 hours ago, John1567890 said: Okay thank you yes I was thinking that this would be the case alright would I be able to take connectors from the saloon and solder the wiring into the estate connectors the same and wires are the same colours going to each pin also after I replace the ccm will have to reprogram the ccm ? Now that I'm not sure. It's a risk for sure. Might be smooth seeking the advice from an auto electrician on that one.
daveyboy1967 Posted 12 hours ago Posted 12 hours ago (edited) 19 hours ago, John1567890 said: I replace the ccm will have to reprogram the ccm ? I replaced the CCM in my '03 A6 C5 1.9TDI with one that had the identical part number a couple of months ago and it was completely plug and play. Your key fobs will need to be reprogrammed however, but it's a really quick and straightforward job if you have two. I posted a guide in the C5 forum that explains it step by step. Hope that helps you mate. Edit I've just noticed the CCM in your avant ends in an N and the saloon in a K, weirdly the one in my saloon is an N, go figure. Edited 12 hours ago by daveyboy1967 Additional info 3
John1567890 Posted 11 hours ago Author Posted 11 hours ago Hello thanks for the advice the ccm ending in a K is only up to 2002 the saloon I have is a 2001 I have found a ccm online identical part numbers so I must get that ordered and now I must try and salvage a few of my connectors instead of having to rewire in all new ones I was thinking of trying to split the case of my own ccm and salvage it but when I got to the inside I can firmly say it is long gone unfortunately hahaha
