John1567890 Posted June 12 Posted June 12 Hello just after buying 2003 C5 a6 avant I bought the car assuming ccm was the issue for all interior issues. Took it out and I was right but the connectors are destroyed with corrosion. I have a 2001 saloon a6 but the ccm does not match it is only one digit off on the part number the avant has an N and the sallon a K would I be able to use this ccm. I must now try to cut connectors off and solder in new connectors if somebody knows if these ccms are interchangeable that would be very helpful thanks
Steve Q Posted June 12 Posted June 12 They're not interchangeable. You need to swap the failed part out for one that has the exact same part number 1
John1567890 Posted June 12 Author Posted June 12 Okay thank you yes I was thinking that this would be the case alright would I be able to take connectors from the saloon and solder the wiring into the estate connectors the same and wires are the same colours going to each pin also after I replace the ccm will have to reprogram the ccm ?
Steve Q Posted June 13 Posted June 13 13 hours ago, John1567890 said: Okay thank you yes I was thinking that this would be the case alright would I be able to take connectors from the saloon and solder the wiring into the estate connectors the same and wires are the same colours going to each pin also after I replace the ccm will have to reprogram the ccm ? Now that I'm not sure. It's a risk for sure. Might be smooth seeking the advice from an auto electrician on that one.
daveyboy1967 Posted June 13 Posted June 13 (edited) 19 hours ago, John1567890 said: I replace the ccm will have to reprogram the ccm ? I replaced the CCM in my '03 A6 C5 1.9TDI with one that had the identical part number a couple of months ago and it was completely plug and play. Your key fobs will need to be reprogrammed however, but it's a really quick and straightforward job if you have two. I posted a guide in the C5 forum that explains it step by step. Hope that helps you mate. Edit I've just noticed the CCM in your avant ends in an N and the saloon in a K, weirdly the one in my saloon is an N, go figure. Edited June 13 by daveyboy1967 Additional info 3
John1567890 Posted June 13 Author Posted June 13 Hello thanks for the advice the ccm ending in a K is only up to 2002 the saloon I have is a 2001 I have found a ccm online identical part numbers so I must get that ordered and now I must try and salvage a few of my connectors instead of having to rewire in all new ones I was thinking of trying to split the case of my own ccm and salvage it but when I got to the inside I can firmly say it is long gone unfortunately hahaha
John1567890 Posted Sunday at 02:16 PM Author Posted Sunday at 02:16 PM Hello I ordered a ccm with identical part number from Germany took a while to come when I was buying it I asked the seller to cut the connectors off and give me a bit of wire to also work with when rewiring cut off my main black block connector and got my new connector and soldered it in I plugged in my new ccm and everything is working windows and also interior lights the doors aren’t locking I’m thinking due to the keys not being programmed will do that during the week with a vcds. Only main thing left to really do is fix my boosting issue I found the problem with the vacuum pipe which goes onto the nipple on the side of the tandem pump may try and use chemichal metal to reinforce the nipple and prevent the leak first before possibly replacing the pump .
Steve Q Posted Sunday at 04:11 PM Posted Sunday at 04:11 PM Sounds like you're getting there 🙂 keep us posted if the key reprogramming fixes the issue. 1
daveyboy1967 Posted Monday at 10:22 AM Posted Monday at 10:22 AM 20 hours ago, John1567890 said: the doors aren’t locking I’m thinking due to the keys not being programmed will do that during the week with a vcds. Seriously mate, I'd try this method first as it's really simple (especially as you have two keys), works perfectly, and is so idiot proof even I managed it at the first attempt. You don't need to mess around with the VCDS clearing memory slots or anything like that and you'll have both your keys programmed in two minutes with zero fuss. I'd change the batteries in them first to save messing around in the future. The information and instruction you need starts 9.00 minutes into the video. I wish I'd found it ages ago as it would've saved me a load of hassle in the past. Let us know how you get on please. 2003 A6 C5 key reprogramming (two key method) - Audi A6 (C5) Forum - Audi Owners Club (UK) 1
John1567890 Posted Monday at 11:48 AM Author Posted Monday at 11:48 AM Oh super job I’ll try that out later thanks very much appreciate that dave I replaced the key batteries yesterday so I’ll watch the video later thank you
daveyboy1967 Posted Monday at 12:26 PM Posted Monday at 12:26 PM It really couldn't be simpler or more straightforward if you've got two keys mate.
John1567890 Posted 3 hours ago Author Posted 3 hours ago (edited) IMG_3583.mov Hello again I was not able to code the keys in this way unfortunately it wouldn’t allow me I just coded them with vcds . I have another issue the car is down on power and is misfiring with white smoke I have no fault codes present I’m thinking possibly injector issue I’m a bit confused by it hahaha what are yere thoughts I attached a video I’m not sure if ye can see it or not IMG_3583.mov Edited 3 hours ago by John1567890
Steve Q Posted 1 hour ago Posted 1 hour ago 2 hours ago, John1567890 said: IMG_3583.mov 16.13 MB · 0 downloads Hello again I was not able to code the keys in this way unfortunately it wouldn’t allow me I just coded them with vcds . I have another issue the car is down on power and is misfiring with white smoke I have no fault codes present I’m thinking possibly injector issue I’m a bit confused by it hahaha what are yere thoughts I attached a video I’m not sure if ye can see it or not IMG_3583.mov 16.13 MB · 0 downloads Sorry to hear of your other issue. What engine has the car got?
John1567890 Posted 1 hour ago Author Posted 1 hour ago Yeah it’s very annoying this is my last issue tho hahaha hopefully 🤞 I have a pd130 awx code
Steve Q Posted 47 minutes ago Posted 47 minutes ago Pd engine is a very reliable engine. Check for mayo round the oil filler. Might be worth getting the engine pressure tested. Obviously worse case scenario is a head gasket.
