Jamesy256 Posted 4 hours ago Posted 4 hours ago Home from work early, beautiful day so decided to take the s3 out for a spin. Pulled out of a junction 2nd gear pull and car immediately drops power,stays in second and gearbox malfunction comes up. Limited performance. Turned off and on and it reset. Seems fine on higher gear pulls but same issue happened again twice when setting off. I do think the shifts are a bit rough sometimes now. I did the usual reset of the mech unit the other week too. Anyone have any issues like this. Car is stage one map but gearbox standard. Would this have an effect ? Thanks
cliffcoggin Posted 4 hours ago Posted 4 hours ago Is this the same car you asked about in https://www.audiownersclub.com/forums/topic/28800-gearbox-issues-s3-8v/#comment-116099 and failed to update the forum as requested?
Jamesy256 Posted 4 hours ago Author Posted 4 hours ago It is. Sorry I forgot all about it. I removed r600 air intake and res delete and it solved the issue last time. It’s been running fine ever since until today.
Steve Q Posted 3 hours ago Posted 3 hours ago As per my previous advice it definitely could be the megatronics unit. You could try and get the gearbox oil changed to see if that helps.
Jamesy256 Posted 3 hours ago Author Posted 3 hours ago Il book it in for a warrenty call. And will remember to keep the forum updated. Bad timing as I just put the car up for sale. Drove an rs3 yesterday and planning to upgrade
