Hi there
I’m new on here and was just wondering if my manufacturer retractable tow bar is compatible with the alko caravan towing systems? I’m pretty sure it will be but just checking.
thanks in advance
Ryan
I don't know for certain, but what I have read indicated the Alko hitch needs more clearance around it than others, hence some installers recommend a swan neck mounted ball. I suggest you measure the clearances around your ball and ask Alko if it is suitable.
Thank you - yes I have contacted ALKO Cheers
