Front light washers possibly blocked
Anyone had this issue before? The washers come out the front so the mechanism works but nothing sprays out. I’m assuming it’s blocked but I have no idea how to unblock as it’s very tricky to get to.
Hi its likely the supply pipes have collapsed but I would try to listen to hear if the pump is buzzing when you activate the washer system if it isn't its probably the main pump blocked or knackered.
