What’s this please ?
Afternoon folks,
Could someone tell me what this double ended torx screw driver is for please ? I have found it among the jack ect in the boot . But where all the accessories has a place moulded for it ,this doesn’t seem to fit anywhere ? I would appreciate your thoughts please .
7 minutes ago, Adder said:
Afternoon folks,
Hi its a get you out of trouble screwdriver, it should have a plastic handle somewhere, they are pretty useless you will be better off buying a little Draper 1/4 drive socket set and a US Pro 1/4 drive torx set for around £50 for both that covers just about every fixing in the engine bay.
Cheers Steve for your reply,
I can well imagine it’s pretty useless, because a, of the things you may need a double ended t30 bit and b, where would you use it because it’s about 10” long  long !
regards
Adder
  • 2 months later...
You can use it for air filter box. And use the handle from the small screwdriver.
