B9 2.0 Tdi Fuel filter change question
Hi all, I need to change the fuel filter on my 2017 2.0 Tdi as part of the service interval and wondered if I can bleed it out from the engine with a hand pump or does it have to be done using special software?
Edited by 1157jonboy
Spelling mistake
Hi you can bleed the fuel filter using the ignition, when you change the filter fill the new one as much as possible with fuel [messy] then once connected without starting the engine cycle the ignition on for at least ten second intervals twelve times, once its running leave for a minimum of five minutes to allow the HPFP to self bleed.
