windows and sunroof not working
had a issue with my ignition ,while changing it out the car went into safe mode could not get the immobilizer to turn off even at the dealer so i had a immobilizer delete done , now the car srtarts and drives but the power windows don't work , safe is still on on the dash
Hi thats the problem with trying anything ignition based, it thinks its being stolen chances are the immobiliser is fried, can't see why the dealer can't do it, when this occurs the can gateway will lock a lot of functions out, if you have VCDS you can reset at lot of this, never understood mapping out certain problems as it wont cure the root cause.
