Coupe gt 1982 power windows
Hi looking for the location of power window fuse relay as both windows stopped working if anyone can help thanks
Hi Gareth yes I have but it doesn't seem to give the location of the relay, it's not in the main fuse box , I have the early model, the radio has also stopped working
Thanks in advance
Thanks Ray,
Window operation failure could be linked to fractured wires within the flexible harness twixt the A post and the door frame. Having said that, it’s generally the most used driver door which gives trouble, but worth an inspection.
Regards,
Cheers Gareth yes I will check the wiring at the door never thought of it .
