Front wheel bearing which way round
Got a bearing Kit noticed the internal diameter has two different diameters 38.7 and 40.7 which way should face out or doesn't it matter ?
Edited by Mrglee
Solved by Mrglee
Hi you could try looking at the original when you take the hub off that should tell you straight away.
  • Solution
Cheers Steve got it sorted now bearing would be fitted with bigger internal diameter facing out.
