H&R springs
Hello, I have a 2014 Audi A6 C7 front wheel drive engine code cnha, I purchased the car with H&R springs, the tires are wearing out on the inside on the front, after alignment I have -1.57 on the left and -1.37 on the right, what do you think is the cause of the tire wear? Thank you
Hi probably the twice as thick aftermarket spring and the oversize wheels which won't allow a lot of movement when going over bumps, therefore it pulls the lower arm bushings and takes it out on the tyres.
