Engine fault light
Hello everyone I got a engine fault light and diagnostics is saying
P201500
Intake Manifold Runner Position Sensor/Switch Circuit-Range/Performance
Has anyone had this before and if so what do you recommend ?
Thank you
P201500
Thank you
Hi its the swirl flaps sticking, there may be a delete kit for it but either way the manifold will have to come off and be cleaned, the code means the flaps can't move within the specified range, you may get lucky at this stage and get away with just cleaning it and getting it moving.
Steve
