2022 A6 avant 40 TFSI - clicking noise when turning
Hi all,
Looking for some guidance on a noise issue on a 2022 Audi A6 Avant 40 TFSI (C8). I’ve attached a couple of short videos—would really appreciate if you could listen and share your thoughts.
Symptoms:
- Fast, rhythmic clicking noise when turning
- Happens under acceleration/load (not noticeable when coasting)
- Frequency increases with speed
- Sounds like it’s coming from the front/undercarriage area
In the videos:
- The noise is clearest during turns under throttle
- You should be able to hear a rapid, repeating clicking that speeds up with wheel rotation
Additional observations:
- No warning lights on the dash
- No noticeable vibration through the steering wheel
- Not a single clunk — it’s a continuous
Context:
- Recently purchased from a non-Audi dealer
- No known accident history
- No visible damage to CV bush from underside of the car
Question:
Does this sound like a CV joint (likely front right outer), or are there other common causes on the C8 A6 I should check first?
Also—on these cars, is it better to replace just the joint or the full driveshaft?
Thanks in advance.
https://drive.google.com/drive/folders/1HuBj-eiVM0N1AZkWiRHHEHI4G6qwfXUX?usp=share_link
Edited by Avanticum
