Actuator tip
Hi all
Just a quick tip I thought to share for ANY actuator link arm which is worn . I was getting the famous p2015 fault code 'actuator in unexpected position', mine was caused by a worn actuator motor link arm which was flapping about on its rod due to it being worn and very loose. I fixed it by pushing on a star lock washer and a small cable tie for added security. Works a treat and a very cheap fix for this issue. 20260514_144812.jpg
