Upgrading Headlights/Rear tail lights
Hi,
We have an A8 2004 6.0L Saloon OV54 CXE and I have been asked to purchase 2 x headlamp units and rear inner/outer tail light units. The problem I have is that the customer doesn't want a like for like replacements but wants to update them with a later design.
I'm not sure that this is possible but any advice would be gratefully received.
Thanks,
Gareth
Hi Clifford, Thanks for the reply.
To be honest, what I've been tasked to do may be a fools errand.
The criteria is that he wants to update the headlights and rear lights with a more modern 'bling' type style. Whether that is LED or not.
The problem is finding out from someone what other lights can be used instead which fit the vehicle.
He was hoping someone on this forum had done a similar conversion project.
I am at a loss of who to ask. I am used to replacing like for like parts.
Cheers,
Gareth
Issue 1. If the car has halogen headlights and the owner wants to convert to xenon then the car will need a headlight washer system installed to make it road legal.
If I'm not mistaken this version of A8 (d3) was made untill 2009 so fitting later headlights and tail lights might be an option. But the later units would be coded to the car as can us was brought in in 2007.
  • 7 months later...
Old topic
But something is bugging me,
Cars with projector headlights that have OEM xenon bulbs must have washers, Ok.
Modern LEDs are blinding compared to xenon and they do not require washers What's the deal?
But you can fit LEDs to projector type headlight units.
9 hours ago, Rybrook said:
Old topic
Have had all three. Projector halogen in B5 A4 2.5TDI Quattro, no headlight washers. Bi-xenon in B8 A4 Allroad with headlight washers and LED rear, and now B9 A4 Allroad with LED front and rear, that ironically has headlight washers (in bumper) but was never fitted from factory. I’m planning to retrofit.
Halogen and xenon generate heat, LED doesn’t, hence requirement for washers. Suspect the headlight washer bumper flap is for those that request it as extra or LED Matrix which I think is available on top of range Vorsprung.
Upgrading lights is never straight forward. Minimum is you will need VCDS for coding, and parts need to be new as usually have security protection.
