Battery replacement
Hello All - My battery has died and I'm all set to replace it myself. We jumpstarted the car last week and despite it initially sending me a lot of mad messages about nothing working, once I got it going and drove a mile, it was all fine. 2 days later, battery flat again. Mu question is, if I disconnect the old battery and replace it, will all my computer settings be lost?
Solved by Magnet
  • Solution
Hello Lucy,
How old is the current battery? I ask since there maybe a current drain on it, rather than it just being well passed it’s best. If it’s over 5 year old, it would be wise to renew it anyway.
What brand are you intending buying? Important, since these cars are certainly battery-efficiency sensitive.
To ensure you don’t lose any codes then you would be wise to invest in a a cheap saver device, which acts to keep 12v to the battery cables when they are disconnected.
Finally, you will need to code the new battery to the car, otherwise it could be seriously damaged by being overcharged.
A forum search will come up with the advice you need.
All in all, a DIY replacement may not be your best option in your case.
Regards,
Thankyou so much for this. It's around 5 years old but I will definitely follow up on what you've said when I've finished painting the kitchen! Very best, Lucy
Thanks so much, Gareth. In the end I rang the garage and he thinks he can do it on Monday morning. So very different from the days when you just undid the terminals and replaced the battery.
