Steering wheel Replacement
Hey I have a Audi A4 B8 and I want to change my steering wheel. I bought a new one online and it was suposed to work . Unfortunately It seems that the connectors are not the same and hence dont fit . From my knowledge and research the airbag code comes from a A1 . Some people told me that I just need to change the airbag not the whole wheel . Others told me i have to change both . Others told me that I might be able to rewire the harness . Could you give me some insight on this matter ? See images bellow for reference ! Please any help would be useful .
Edited by GiannisTz
Hi you can't just swap the airbag module as the steering wheel originally fitted is completely different, an auto electrician could probably sort the wiring but the new wheel would need coding in and thats if you don't need another control module.
Look up your own car via LLL parts, especially the stock steering wheel and take a note of the part number. Now cross reference that with other steering wheel variants of the same model up to the final build year, which I think was 2015. They should all be compatible.
Auto electricians, recoding, sounds like a lot of work.
Hate to point this out but even if you fit a new steering angle sensor you have to recode it, if it sounds like a lot of work, its not half as much work if you don't get the wiring right as well as the coding, the electronics on these vehicles has always been complex and if you fry a body control module [any one of about five] you then have a serious problem.
