Brake pad warning
I have a 2018 Q5 that has done about 14k from new. it stands outside. I have had three brake pad warnings this year. They don't look worn down but I wonder if they deteriorate with age. I was at my usual garage a months ago and they said that they looked OK.
Hi if it stands for a long time the only thing that deteriorates is the pad sensor wires easy enough to replace and cheap enough aftermarket.
Into the garage on Monday
New sensors all round and new brake pads at the front - they did warn that they didn't look too worn before they changed them, but I told them to go ahead and change them just in case.
Working OK now which is the main thing.
