Audi S3 rear diff
Hi guys.
New to the forum but have had VW/Audi for a few years now and have just bought a 2014 S3. Never had a 4wd/quattro before. Got it for reasonable money as there is a noise in the rear which I am pretty sure is the rear diff.
Doesn’t seem to be a wheel bearing as noise doesn’t change with change of direction and it seems to get a bit louder when I let off throttle/coast. Again never diagnosed anything with a 4wd system so from reading forums that seems to equate to possibly rear diff.
Question is will a rear diff from a same year A3 1.8 FSI Quattro fit? Part numbers are the same and letter at the end is.
I intend to drain a little bit of diff oil and see if any metal in it.
Any help would be greatly appreciated.
Thanks in advance and looking forward to sharing any experiences or knowledge I have along the way.
Hi. Not sure on the compatibility but not sure if you’re aware there is a haldex unit which sits in front of the diff. This is usually disengaged so the power is to the front wheels only unless the system detects slip at which point the rears are engaged by the haldex. The haldex unit should be serviced every 20000 miles. Might be worth looking at that as well as I believe they can cause problems.
My understanding is Audi just change the oil, however there's a mesh filter which needs cleaned. Pretty sure it will be 5 generation Haldex.
