2021 A3 (8Y) Etron charging with intelligent Octopus Go
Is anybody having trouble charging with Octopus Go. I have been trying for 2 weeks to get my A3 to charge without success. I have at octopus's suggestion fitted a new 12v Battery (new battery was coded to the car) and that night full charge was successful. Since then small amount of charge or nothing. I have switched off the car timers as Octopus suggest to no avail. Interestingly after a failed charge one of the timers has changed to a random date in the future. Communication with the car does not seem to be a problem as Octopus are able to switch the charge off when I plug in outside the cheap rate hours (11.30.to 05.30) as normal.
I have switched off any charge settings in the my audi app - again at octopus suggestion
Octopus are suggesting that there may be a problem with the AUDI cloud servers.
Any input welcome
MikeB4
Mike.
Is that a new problem or has charging always been troublesome?
It is not clear to me what device is supposedly controlling charging. Is it [1] a wall mounted charge point, [2] the car itself, or [3] the Audi app on your phone? Can you clarify please? All three have timers which can conflict with each other.
[1] and [3] both require an internet or mobile signal, [2] needs no external service and hence one might expect it to be more reliable , however history on this forum has proven the matter of car charging to be problematic to say the least.
My own experience of car charging via five different wall boxes was a nightmare that only ended when I got rid of them all, and reverted to a simple plug in charge point (the so-called granny charger) with a built in delay timer. I have to admit that was more to do with the car's inadequate software than any deficiencies of the wall boxes, but it has made me aware that it is too easy for those companies to pass the blame for faults on to each other.
The charging is supposed to be controlled by Octopus under their intelligent go tariff that gives good rate between 11.30 pm and 05.30am. I have turned off the charge timers in the car and am using the 3 pin granny charger that has no timer function. When I plug in and switch on the charger starts charging as indicated by the pulsing light on both charger and car. After a short time Octopus recognises that I want to charge, presumably a signal from the car, and they tell the car to stop the charge and send me their proposed schedule, on their app of charging through the cheap rate period. I have been doing this for the two years or so that I have owned the car. The problems started about 3 months ago after I started getting messages that the 12v battery was low. After replacing the battery, including telling the car that it had been changed, the first charge worked fine, but since then nothing but trouble.
I have noticed that after a failed attempt to charge one of the car timers that I have turned off is showing that it as set up for a charge some days in the future and has mysteriously turned itself on, definitely not by me!
The only settings I have made are in the Octopus app - Level of charge required and by what time
Thanks for the clarification Mike.
Having established that the system did work as expected for a considerable time under Octopus's control via its app, and then stopped working after a 12 volt fault and subsequent battery change, two possibilities occur to me. Firstly the cars charging circuits may have been affected by the 12 volt fault. That can be tested by using another granny charger at another location and without any involvement of an app. Is that possible by visiting another EV owner with working equipment? Do you have another granny charger of your own you can take elsewhere? The other possibility is the internet connection in the car has been affected by the 12 volt fault. I don't really know how you can test that unfortunately.
Sorry I can not be more precise. I believe the way to isolate the source of the problem is to change just one part of the system at a time i.e. charger, location, app involvement, wifi signal. Alternatively take the car to Audi for diagnosis though you don't need me to tell you that is going to be expensive.
It is not widely appreciated that EVs are surprisingly prone to 12 volt problems. Some manufacturers even recommend a new battery every three years.
Do you have to use their app? My wife has a BMW i3 that has onboard computer that can delay charging. We recently switched electricity providers (don’t ask me who) as we have solar and battery storage. The 7kWh wall charger is currently out of action until an electrician tests the cable. It’s been on from 2018 but I suspect it needs a new tethered cable as works intermittently.
In the meantime she can use 13A granny charger or a public charger. Cheap tariff is midnight to 6.00am. The new electricity provider wants us to use their custom app. However the car has its own software to delay charging, so we use that. It’s also intelligent enough to start charging earlier if need be as 13A will take longer compared to 7kWh. Granted, some of this power is outwith low tariff but that’s fine as we have battery storage.
My point is, does Audi have this interface, rather than use the app which has to work across multiple car platforms?
