RS7 C8 coolant pump error
I had the BSG replaced on my 2020 RS7, and after 2 days from taking it back from the delearship i scanned it just to see if any historic errors are present, and i saw the coolant pump error. Nothing came up on my dashboard, but i still took it back to Audi because i thought they left air in the cooling system. They had it refilled, and claimed they used the correct process, but today when I started the car the error came back. Still nothing on the dash. Has anybody had anything similar? I'm going back to Audi tomorrow.
Hi could be an auxiliary water pump they use these to circulate the water if the weather is hot after the engine is stopped it prevents cooking the cylinder head, by the looks of the coolant temp it was already hot when you started the car.
