Engine whirring noise
I’ve noticed recently that I’m getting a whirring noise between about 2-4 rpm when the cars up to temp. The warmer it gets the more noticeable it is. I thought it might be something to do with the drive train etc but when it’s happening, if I disengage the clutch and the engine drops to idle the noise goes away. Bring the clutch pedal back up again, noise returns? Sounds abit like a wheel bearing
Hello Dan,
I guess your description is taken as an in-motion symptom.
What happens if you get the car up to operating temperature preferably after say a 5+ mile run, then at standstill, increase the revs and hold to a steady 3k and check the existence of any noises with clutch pedal not-depressed and depressed?
Regards,
Hi Gareth!
I have just done this and the noise is still there, I think it might be the alternator, it’s hard to tell as it’s so !Removed! tight in the engine bay!
Ha, it was a very mild swear word, nothing to note!😂 I parked up and just revere it up to 3k rpm and held it for a few seconds in neutral. Still made the noise, if anything it was a bit loader as we weren’t moving
Yes, I think it’s a pulley on the engine
Hello Dan,
How about an answer to my last question?
Not being critical, but being realistic, ‘…I think ….pulley…’ Thinking it may be something is a sure way of damaging your wallet?
Regards,
I didn’t touch the clutch peddle, just gave it a rev up in neutral and the noise just got louder as the revs rose up
