Denispearl Posted May 1, 2016 Share Posted May 1, 2016 Greeting to all. Hope you all well. I have recently developed strange issue with a rear light , as per picture. Just noticed today that 2 sectors on the rear read light , right side are constantly on, despite the fact that brakes arent engaged. What could that be? Ddn't do anything to the car, apart of puting it through the hand wash today and polishing/waxing later. Thanks a ton for your input in advance. Quote Link to comment Share on other sites More sharing options...
Brucielee Posted May 1, 2016 Share Posted May 1, 2016 How's things and hello to you, welcome to the club First thing I'd check is the switch behind the brake pedal, make sure it's not stuck on, if it is its fairley cheap and easy to fix Quote Link to comment Share on other sites More sharing options...
Denispearl Posted May 1, 2016 Author Share Posted May 1, 2016 Thanks for welcoming and an advise . will do Quote Link to comment Share on other sites More sharing options...
caraitis Posted May 2, 2016 Share Posted May 2, 2016 FOG lights maybe on ? Quote Link to comment Share on other sites More sharing options...
Denispearl Posted May 3, 2016 Author Share Posted May 3, 2016 Hello all. thanks for the all input. Unfortunately the fog light is off Many thanks Quote Link to comment Share on other sites More sharing options...
Denispearl Posted May 3, 2016 Author Share Posted May 3, 2016 On 01/05/2016 at 11:48 PM, Brucielee said: How's things and hello to you, welcome to the club First thing I'd check is the switch behind the brake pedal, make sure it's not stuck on, if it is its fairley cheap and easy to fix I cannot check the switch as couldn't find. Could you please advice if possible on where is it located ? Thank you kindly Quote Link to comment Share on other sites More sharing options...
Brucielee Posted May 3, 2016 Share Posted May 3, 2016 You need to get up behind the brake pedal to reach it, probably best taking of the plastic trim that is below the steering column to see it clearly, Pull the brake pedal towards you and have someone watch the lights to see if they go out or not, just out of curiosity Quote Link to comment Share on other sites More sharing options...
Denispearl Posted May 25, 2016 Author Share Posted May 25, 2016 all sorted. Simple bulbs change Quote Link to comment Share on other sites More sharing options...
James Posted May 25, 2016 Share Posted May 25, 2016 2 hours ago, Denispearl said: all sorted. Simple bulbs change Love it when you get a nice and simple result! Quote Link to comment Share on other sites More sharing options...
Denispearl Posted August 20, 2016 Author Share Posted August 20, 2016 :)))) Quote Link to comment Share on other sites More sharing options...
