Q5 daytime running lights
Hi all
my first post one here and I wanted to know if anyone has changed their daytime running lights to LED's? I have a 2009 Q5 with non xenon headlights.
i spoke to the local dealer who said it isn't possible to fit LED's as running lights.
Just wondered if anyone can say otherwise? If so, which bulbs / sets did you use ?
thanks in anticipation
Hi Kevin...welcome to the Forum
I believe you can run auxiliary (aftermarket) LED running lamps as a road-legal option which would be cheaper than modifying your standard lighting to incorporate LEDs
Link to Headlamps with LED   http://www.audiownersclub.com/parts-results/Q5/Headlight-Assemblies/44240
Link to other lighting components   http://www.audiownersclub.com/parts-results/Q5/Other-External-Lighting-Parts/174065
Let us know how you get on with your project
Cheers   Trevor
