Air con
Hi all, I've got an issue with my air conditioning running all the time, the switch/button for all 3 of air con/ rear heated window and air recirculating don't illuminate so I can't tell if their actually on, also no lights for the blower dials, any suggestions please. Audi A3 TDI 2.0 sportback 2008
Hi Russell
Welcome to the forum!
Either a loose wire or that whole unit is on the way out/gone. when did it start going funny?
Regards
Bradley
Hi Bradley,
The past couple of days since I had another issue with my rear tail light, resolved that water getting in the casing, do you mean a loose wire to the unit itself, is it possible to remove the unit?
Glad you got your tail light fixed! :) and yes in the unit itself, you should be able to use a tool of some sort to get it out but looking online I found this..
From online
" The surround of your hazards buttons ect if you have double din just unclips off and then pull the climate unit down and forward at same time with a little force and will just come out easy as that"
I hope this helps
Bradley
