Engine rattle
JasonTT
hi people,
new to the forum, hoping to find out what this !Removed! noise is.
First of all this is not my engine but it's the same noise.
Now some history... has the cam chain tensioner changed due to CEL on, that cured that, had timing belt area checked all ok, had it at a specialist and he is stumped, reckons it's coming from vac pump but changed that and it's still there.
Many help would be seriously appreciated guys !
I know the TFSI engine is noisy by its very nature (being high pressure injection) and can sound somewhat like a diesel engine.
Other noises I could hear are the injectors....which do 'clack' rather loudly.
Could possibly suggest replacing the oil with a better quality brand and also the grade to facilitate smoother running from cold.
Thank you very much for you're reply Trevor. Very much appreciated.
My car has been at an independent specialist having the cam tensioner changed. It makes this noise when warm not at cold start, it wasn't there before it went in and the oil was changed. I'm just worried that I've paid £800 to have it fixed only to inherit another problem. It's driving me crazy !
Is it just the sound that is the issue? is there any other issues? like starting up, rough idle, more smoke, mpg ect?
@Trevor could it be a faulty injector ? as you said they are loud anyway but could this be one that's gone bad? that's what pops into my mind.
Regards
Bradley
The car now it's had the cam chain tensioner drives like a dream, it is slightly rough only on the odd occasion at idle. Mpg I'm not sure because I haven't got it back yet. I've noticed no smoke, and the rattle is coming from cam BELT area but he assures me all is good with that. At cold start the engine is silent, I'd say brand new, but when it's warm it rattles.
If the problem was serious would it not drive as well as it does. It's only done 74k but the Audi specialist even commented on how well it drives !
I doubt if it is a faulty injector but if it is anything like a diesel injector with seals, then it maybe a case of an injector not being seated / sealed correctly (if removed) when refitted?
Hi guys
once again I'm back with this rather annoying noise, fine all that was advised. Cam tensioner and oils changed. Engine is silent at cold start, only rattles like a tractor when warm
I've managed to upload a clip
any help or suggestions greatly appreciated
thanks
IMG_8652.MOV
Oh no!
Have a look to see if your engine mounts are fine, do your pedals move or vibrate at all? is there any noticeable thing that the car does as well as this rattle when warm?
Regards
Bradley
