Flywheel and Clutch
Hi guys
I have an Audi A4 1.8 TFSI. Just been told the Clutch and Flywheel needing replaced. :( Quoted £850 all in.
£500 for the Flywheel.
£150 for Clutch and £200 Labour.
Is this about right?
Hello Abby,
The labour charge would seem to be very reasonable to me. As for the parts, you can go down the route of cheapest will do, and take a chance on the components lasting - which would not be my approach if it were my car.
I would be shopping around for good quality parts at the the best prices, and if not using VAG parts (available at discount) then I would only consider LUK clutch parts as an aftermarket alternative. Other aftermarket makes may be cheaper, but... In the long run...?
