KEY FOB WON'T OPEN PASSENGER DOOR 2007 TT
Hi folks,
Not very good with Tech on forums or Pc's ,can anyone help the central locking remote has all of a sudden started playing up .The remote key fob will open everything except the passenger door .Only way to open is to lean over from the inside. Once this is done it can be opened from the outside. Is there any basic cost free options to start with.As everything seems to be going wrong at once!!!
Much appreciated,
Rob Ellis (stressed lol)
Get a vcds scan by a garage first . Its most likey actuator that failed .
When you unlock with the key can you hear any noise from the passager door ?
Hi thanks for the speedy reply, no I can't here anything,however the door will lock by the fob,just won;t open!!!
Hi Rob i had a similar issue when i 1st got my car but was the drivers door all other doors locked and unlocked apart from drivers, dealer i got the car from had to order a part from audi it was a switch of some sort mechanical part that locked and unlocked the door.
no issues since it was replaced.
