Diesel leak from engine
Has anyone had similar problems or would know the cause of a small diesel leak? No warning lights but the power seems to be lacking a bit? Was told it was leaking from here?? Any help would be great thanks.
Welcome to the forum Colm, you'll find the members on here are a friendly and helpful bunch :)
Have you had a diagnostic check carried out? And if so this is what I'd recommend. Plis, if the garage have advised you this is the area where the diesel is escaping from, why haven't they replaced the faulty part?
Hi Steve, I got it sorted it was an older fuel temperature sensor that wasn’t sealing properly so got it replaced and seems to be fine now.
That's a result :) glad it's sorted :)
