LifeOfRyan Posted April 25, 2018 Share Posted April 25, 2018 Hi everyone I hope you are all well. I bought My Audi A4 B5 1.8 non turbo with engine code AVV about 3 weeks ago. When i went to look at it i knew something was wrong and I should have walked away but the guy kept talking to me diverting my attention away to a tear in the seat, I have autism so I became very confused and bought it anyway for 550 pounds which was all the money I had in the world. When I got home which was only a 5min drive away I immediately regretted buying the car and knew i made a big mistake. I turned the engine off and tried to start again and it did eventually but it took a long time and idled with a misfire or several. It starts easier when warm but from cold it takes a good 60 seconds of turning the key before it stutters into life. At first it sounds like its only running on 1 or 2 cylinders but then after about 5 seconds as revs increase the others do fire but still with a lumpy idle. I tried to take it back and explained my situation but all the guy said was Sorry sold. I have had a friend look at it and attempt to fix it, he replaced the inlet manifold gasket as we saw smoke rising from that area and after removing the manifold he also found a big hole in the crankcase breather hose which has been replaced, but the car still takes a very long time to start from cold and still idles rough? Any advice will be very much appreciated im hoping it can be repaired cheaply by my friend as I don't have alot of money so I need some pointers as to what it could be. Also my friend does not think it is the head gasket that's failed as there is no smoke from exhaust just white smoke (water vapour) from a cold start. Thanks again Quote Link to comment Share on other sites More sharing options...
Steve Q Posted April 26, 2018 Share Posted April 26, 2018 Welcome to the forum Ryan, you'll find the members on here are a friendly and helpful bunch :) The other things you could look at changing are the ht leads, distributor and spark plugs to see if that improves the starting of the a4. Cheers Steve Quote Link to comment Share on other sites More sharing options...
StuPotA4B5 Posted May 1, 2018 Share Posted May 1, 2018 Hello Ryan, I'm down the road in drayton, PO6. Bring it round and I'll plug it into my VCDS. I too have a 1.8 non turbo so we can try different things :) 1 Quote Link to comment Share on other sites More sharing options...
Steve Q Posted May 2, 2018 Share Posted May 2, 2018 On 5/1/2018 at 9:31 AM, StuPotA4B5 said: Hello Ryan, I'm down the road in drayton, PO6. Bring it round and I'll plug it into my VCDS. I too have a 1.8 non turbo so we can try different things :) That's very good of you Stuart! Top man! :) Quote Link to comment Share on other sites More sharing options...
Magnet Posted May 2, 2018 Share Posted May 2, 2018 I too must say that Stuart's offer really does represent everything which is great about forums such as this. I was going to suggest some possibilities, but no real point now unless for some reason Ryan cannot take up the kind offer. Good luck to you both, Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted May 2, 2018 Share Posted May 2, 2018 9 hours ago, Magnet said: I too must say that Stuart's offer really does represent everything which is great about forums such as this. I was going to suggest some possibilities, but no real point now unless for some reason Ryan cannot take up the kind offer. Good luck to you both, Kind regards, Gareth. Have to agree Gareth. This is what the club is all about :) Quote Link to comment Share on other sites More sharing options...
